01-17-2008 06:53 AM
01-18-2008 03:34 AM
01-21-2008 12:45 PM
This KnowledgeBase should answer your question. You didn't mention how much RAM you have in your system, but this will limit the amount of RAM that your OS can see and use to approximately 3 GB (the actual ammount depends on the system). If this is unacceptable then your only other options are to use a different machine with less RAM, or perhaps use the open source drivers if they support your device.
@Zaph0042 wrote:< www.ni.com="" linux="">
Does that mean that I have to throw away some of my memory? What can I do?
