no device physical detected in Max and Daq Assistant (PCI 6229,6023E)
I got PCI-6229 and PCI-6023E, Daqmx8.1, Max 4.3 and Labview 8.0. Since yesterda I haven't be able to detect these two cards in any way espacially with the Daq assistant or the Measurement and Automation Explorer although the cards are well detected by Win2k.
Can anybody figure out what the problem is? Thank you in advance.
(2,881 Views)
Did you make any operation that could have modify your MAX configuration? (switch card in PCI slots, delete a removed card in MAX, etc.)
I invite you to download and install the 8.6 version of DAQmx, hoping the installation will fix this.
Cordially,
(2,852 Views)
