03-18-2008 12:28 PM - edited 03-18-2008 12:29 PM
I’ve been having problems with noise in my analog inputs. Here is a description of my problem. I hope I have explained the problem clearly.
I have created a VI that outputs signals to 8 loudspeakers (after the signals were amplified from an 8-channel power amplifier). I checked the individual output signals (after amplification), both by reading them back into the computer using a BNC-2090 terminal block and also using an oscilloscope. They have the correct frequency and amplitude as expected.
However, I observe noise in the signals when I connect all 8 signals from the amplifier into the BNC terminal (I input the signals back into the computer, because I need to know the exact signals that goes into the loudspeakers, i.e. after they are amplified). I observe this noise (pic shows signal with and without noise), both on the input waveform graphs and also I can hear a high-pitched noise from the loudspeakers.
To find out whether the noise was caused by all 8 channels being in use; the first thing I did was to use just 1 channel. Once I found that 1 channel gave the correct input signal then I checked 2 channels and so on. I found that if I connect a third coaxial cable to my BNC terminal, this is when the noise starts to kick in. I got the same observation from different coaxial cables, i.e. there’s nothing wrong with the cables. Basically, a third connection to the terminal leads to noise in the input signals.
I tried using bundled up coaxial cables, 5 coaxial cables in a bundle with common ground (I think). However, now I find that a second connection on the BNC terminal lead to noise, as opposed to the third connection with the single coaxial cables.
I suspect that the noise might be something to do with the grounding in the cables or the instruments I’m using (since, the only difference between the bundled coaxial and single coaxial cables is the grounding).
I’m wondering whether anyone could give me some suggestions on what the problem might be, or any further checks I could do. Any help will be much appreciated.
04-14-2008 03:55 PM
Hello Imperial-Aero,
Sounds like you're doing something cool. I have a couple questions that may help us figure out what's going on.
1. Are you generating a single analog output and splitting it 8 times for your amplifier or are you generating 8 analog outputs and sending one to each channel? If you're splitting the signal I'd be inclined to think that it is a cabling issue--something having to do with reflections and impedance issues, but if you're using 8 analog outputs there may be something strange going on with the card.
2. What hardware (DAQ card) are you using to generate the analog output/s?
3. Can you perform a Fourier transform of the waveform you read back into the BNC-2090 with you hear the high pitched noise? It would be interesting to see if the frequency you hear is a harmonic of the frequency you intend to generate.
If you're currently splitting a single analog output 8 times I would recommend trying to generate more than one so you split the signal fewer times. I.e. if your board has 2 analog outputs see if you can split each twice without problems. If this works then it is likely a cabling issue that may be difficult to solve, but you can always get more analog outputs. If you're already using multiple analog outputs then please post back with what hardware you're using and I'll see if I can reproduce the issue on my end.
Cheers,
04-15-2008 01:54 AM
04-17-2008 05:06 AM
