nominal input range
how to choose nominal input range of Single Board RIO?
what is the importance from change it ,for example change nominal input range from ±5 to ±2
(3,232 Views)
Khaled:
 Edit: Please see my response to your question in the Real-Time Measurement and Control board.
You might get a quicker response if you post this question in the  Real-Time Measurement and Control board.
I'm not quite sure I understand your question. Is there a chance you could include some additional information?
 - What model Single Board RIO are you using?
 - What are you measuring with the DIO?
 - Where are you setting the nominal input range (LabVIEW, MAX, etc.)?
Message Edited by charris on 03-09-2010 05:51 PM
Caleb Harris
National Instruments | http://www.ni.com/support
(3,202 Views)
