non-contiguous differential channels
I have four 6axis force transducers hooked up to a PCI-6071e. Each force transducer outputs 6 differential channels.
To create the virtual channel for the first force transducer, I write
ftTask.AIChannels.CreateVoltageChannel("Dev1/ai0:5", "",
                    AITerminalConfiguration.Differential, -0.1, 0.1, AIVoltageUnits.Volts);
But the second force tranducer is hooked up to ai6:7 and ai16:19, ie, the physical channels are non-contiguous because:
(from the help file)
A 64-channel E Series device has physical channels ranging from Dev1/ai0 to Dev1/ai63. You can configure channels in banks of every other eight beginning with 0 through 7 as the positive channel of a differential pair (0-7, 16-23, 32-39, and 48-55). If N is this channel, channel N + 8 is the negative input of the pair.
Does this mean that I can't create a virtual channel with the differential inputs in this physical configuration? If I can, what is the syntax?
Gerry
(3,358 Views)
Nevermind
Gerry
(3,354 Views)
It may help others if you post how you solved this---even if you think it was an obvious thing.
(3,075 Views)
