I use buffered AO to output a waveform on 4 output channels (PCI-6711), and would like the AO to stay at a fixed state which is non-zero after the buffer is done. The analog output is triggered on the rising edge of PFI pin 7, and is set up using a cascade of VIs: AO config - AO write - Trigger Config - AO Write - AO Wait- AO clear. The output always goes to zero after the waveform is output, irrespective of the initial state, irrespective of the last sample, and including after I removed AO clear. The only way I have to return to the desired state is adding an additional 'Single update' afterwards, but this takes ~100ms to kick in, while the waveforms I'm working with are submillisecond.
Thanks for any ideas.
