not seeing PCIe8382 on windows device manager
Hi Everyone,
I installed the NI-DAQ mx 2023 Q4 software first then I installed the PCIe-8382 card. Windows device manager doesn't showed up the card but when I open the NI-MX software it see's the card. Is the normal ? or I'm doing something wrong that Windows device manager is not seeing it.
thanks
(1,690 Views)
PCIe-8382 is not a DAQ card but a MXI controller module. It might appear as an MXI card in Window Device Manager.
https://tmesystems.net/
(1,672 Views)
thank you. I check in device manager it still doesn't showed up. I also install PXI Platform services and it still doesn't showed up in Windows device Manager. any other suggestion? thank you in adavanced
(1,603 Views)
See MXI-Express Compatibility and Connectivity Troubleshooting Guide
(1,593 Views)
It will show up as system devices ("PCI-to-PCI Bridge" or "PCI Express [Up|Down]stream Switch Port")
- Robert
(1,589 Views)
thank you, Both. I check on System Device and I do see "PCI Express [Up|Down]stream Switch Port". I move the PCIe-8382 card to another Dell computer. same results. I even install the MXI OS compatibility but still the same results. I'm leaning thar this is normal for this card.
(1,539 Views)
