ntfs.sys corrupt or missing error on reboot after hardware install.
I am getting an error on reboot after installing my NI hardware - PCI 6023E.
Daqmx version 9.2.3
windows xp
This is the third PC to display this problem. The last PC this happened to was working with the same driver version using different hardware. A USB NI device. Not every PC that is setup has this problem.
Put the 6023E card in and looked if it installed OK, after reboot the error message appears and PC will not boot.
Has anyone had this before or know of any compatibility issues.
Other PC's have used the same driver versions and hardware and function OK. One thing that has changed is kaspersky is now used on the PC's instead of MacAfee and this problem never happened when MacAfee was used.
Neil
(2,900 Views)
Hi Neil
Which version of XP are you using?
You mention other PCs are the same set up but do not have the same problem are they exactly the same?
Does the PC boot in safe mode (hold F8 on boot)?
Do you have other PCIe slots available to try in this machine?
Do other computer boot with this specific device inserted?
Regards
Robert
National Instruments UK & Ireland
(2,879 Views)
