obtain 4 analogue output from 6713
I have purchased a PCI 6713 analogue output card attached to  SCB-68. So far, the board can only output 2 analogue waveform: one from AO0 another from AO1. How can I tap the other analogue output waveforms from other output points from this SCB-68.
Another thing is how can I send digital waveform out from my PCI 6713 card in order to control other equipment that requires TTL signals?
Ridwan
(2,753 Views)
please ignore as i have solved the problem already.
(2,745 Views)
