offset in AIs of PCI-6052E
There is an offset (-118mV) in all of eight differential AI channels in my PCI-6052E card. How can I fix it?
Thanks a lot!
(2,660 Views)
Hello stmxhlu,
Please see this KnowledgeBase about troubleshooting offset readings.  You also may want to try putting the 6052E in another PC to make sure it is not the PC that has this offset.  You can also self calibrate the board in Measurement and Automation Explorer (MAX) by expanding devices and interfaces and then NI DAQmx devices.  Right click on the entry for your board and choose self-calibrate.
I hope these suggestions help!
Laura
(2,641 Views)
