one_shot_ai VB6 example?
I downloaded the one_shot_ai.zip example from NI.  When I opened this example, I got the following 2 errors:
CWDAQ.OCX not found
CWHLPBTN.OCX not found
Do I have install addtional software for this example to work?  I am using VB6 and USB-6009.
Thanks!
Pei-Ying
(3,601 Views)
Pei-Ying,
You will need to install the DAQmx Driver.  Be sure to install support for Visual Basic when you get the option to choose which components to install.
Dustin D
(3,588 Views)
Hi, Dustin,
I did install the latest DAQmx driver (9.1) and did also install the support for Visual Basic 6.  Is there any other software/driver that I need to install?
Thanks!
Pei-Ying
(3,585 Views)
Pei-Ying,
Sounds like you'll actually be needing our Measurment Studio software which allows you to have really good display options for your data.
Dustin D
(3,583 Views)
Thanks Dustin!
Pei-ying
(3,581 Views)
