open collector NI USB 6210
This is just a quick question. I have two DAQs am using a NI USB 6009 and the USB 6210. I've been using the 6009 as open collector outputs. I can't find information about open collector/drain for the 6210.
Can this setup be configured?
Cristian
(3,391 Views)
Accepted by topic author Ibanez
Ibanez,
The digital output channels on the USB-6210 are sourcing outputs.  This module does not allow you to change this setting in software.
Good luck with the rest of your application!
Jared R.
Precision DC Product Support Engineer
(3,383 Views)
Thank you Jared!
(3,381 Views)
