parallel loops
I will attach a picture of my parallel while loops. This is on a cRIO and so I need to reference the FPGA from both loops.
When I run it, the first loop excecutes once then the second loop goes but it never comes back to the first loop.
I am thinking that something with the FPGA reference is holding things up? I just want both loops to excecute independantly.
Attached is a picture. I have the VI if anyone wants to see it further.
Jeff
(3,835 Views)
I would suggest running your VI with Highlight Execution turned on to see exactly where it holds up.  You could also try putting a Disable Diagram around your second loop to see whether or not your first loop runs continuously when it is by itself.  Please post your findings, thanks!
(3,797 Views)
Thanks for the response.
I solved my problem by removing the FPGA reference from one of the loops. Not sure why this works.
Before I did this, the first loop would excetute once, then the second loop would excecute, never returning control to the first.
So now I have one loop that reads buttons and updates the screen, and the other loop accesses the FPGA.
This seems to work but I'm not sure why lol.
Jeff
(3,792 Views)
