pci 6052 E
I wanted to use the Multifunction card PCI-6052, in order to read a voltage coming from another instrument. This voltage is comprised between 0-10V.
I am able to monitor this voltage with a simple multimeter, but i haven't been able read anything correctly with this card. is there any known problem with this card?
I have an offset which derives with a low time constant... and while launching NI-MAX, i have different offsets everytime...
I connect the signal directly without any bias resistor... is this a problem?
In the datasheet, what does 100Gohm in paralell means?
(3,661 Views)
i have understood what was wrong... i simply turned in MAX the configuration of the card from differential to asymetric referenced for Analog input... and it worked...
sorry again for those insignificant postings.
(3,655 Views)
