pcie 6361 multichannel analog input crossed signal
I'm using a pcie 6361 with a scb-68 breakout board to measure two signals simultaneously. My problem is that I am seeing a small trace of signal A in signal B and vice versa.
A simpler explanation of the same problem: if I connect a signal to any of the analog inputs, I can see that signal on every other analog input (very small of course, but present). Is there any way to eliminate that unwanted ghost signal?
Elliot
(4,774 Views)
you have discovered crosstalk due to the multiplexing ADC sample&hold capacitor settling time.
See spec of your card.
Minimize it by
reduce the samplerate and
reduce the source impedance
Greetings from Germany
Henrik
LV since v3.1
(4,754 Views)
Based on your description, you might find the following KnowledgeBase article helpful:
"KB 28MF7JQO: Troubleshooting Unexpected Voltages, Floating, or Crosstalk on Analog Input Channels"
Hopefully these resources can help you work through your issue!
Cameron
(4,730 Views)
Thanks for both of your responses! I've got some work to do.
(4,705 Views)
