pda
Hi
I like to enquire whether is there any way for me to convert a 2D array into 1D array.
If there is , how am i able to connect the data and transfer it into PDA format.
We have found the particular program that is in the example called "play sound" however how can we input into our program
(called the acquire biosignal) to derieve the sound so it can be project on the PDA.
PLS HELP..
thanks lots..
(5,138 Views)
Hey Republic poly,
    What version of LabVIEW are you using?  Why are you wanting to convert a 2D array into a 1D?  What do you mean by PDA format?  If you are interested in using sound within LabVIEW PDA, here and here are a couple of discussion forum posts about the sound VIs in LabVIEW PDA.
Brian B
Account Manager
(5,107 Views)
