phase shift measurement of two PWM Signals
Hi @ All,
this is my first question in this forum and I hope someone can help me.
Use case:
There are 2 PWM Signals with the same frequency and duty cycle and I have to measure the Phase shift between these two signals?
Question:
Is it possible to measure this value directly or somehow indirectly (via calculation)?
Greats
Thomas
(4,231 Views)
Hi Thomas,
had you already had a look at this thread:
How can I measure phase difference between two pulse trains using two counters on multifunction DAQ - Discussion Forums
http://forums.ni.com/t5/LabVIEW/How-can-I-measure-phase-difference-between-two-pulse-trains/td-p/280...
If that couldnt help you yet, please specify your exact hardware and software:
- Are you using LabVIEW? If yes, which version?
- What kind of hardware are you using?
- Do you use counters?
- What range of frequencies do your PWM signals operate in?
Thanks in advance!
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,193 Views)
