physical chanels and xl data for usb ni 6008
Hello , Please guie me about the physical channels of usb 6008,
For example if i use two channels ai 0 and ai 1, connected with battries of 9 volts i see differnt graps as if on the same battries i use channel ai 1 and ai 2,
Second question i am not cleared the data i get in xl sheet as using one chanel, i see two columns in xl showing x and time values but when i use two channels then in xl sheet i see three columns shoing one column x values and two columns of time.i am not cleared about that why i am not getting four coulmns as i am using two channels e,g it shows like this.
Writer_Version 0.92
Reader_Version 1
Separator Tab
Multi_Headings No
X_Columns One
Time_Pref Absolute
Date 14.06.2005
Time 38:01,9
***End_of_Header***
Channels 2
Samples 5 5
Date 14.06.2005 14.06.2005
Time 38:03,4 38:03,4
X_Dimension Time Time
X0 5,72E+17 5,72E+17
Delta_X 0.250000 0.250000
***End_of_Header***
X_Value Comment
57.213.000 -0.004948 0.003865
57.463.000 -0.004948 -0.001231
57.713.000 -0.004948 0.003865
57.963.000 -0.004948 -0.001231
58.213.000 -0.004948 -0.001231
58.463.000 -0.004948 -0.001231
58.713.000 -0.004948 0.003865
58.963.000 -0.004948 -0.001231
59.213.000 -0.004948 -0.001231
59.463.000 -0.004948 -0.001231
59.713.000 -0.004948 0.003865
Please guide me about that
(3,354 Views)
hi sham,
for the measurement have a closer look at this
(at the bottom of the page there is a graphic which shows the different measurement connection types)
when measuring with two channels you get three columns, one for the time and two for the both signals (you have the same time axis for both signals).
it looks like the first column is the time and the two others are your signals.
greets!
(3,338 Views)
Can any one help me to use data logger ni 6008 with labview.My problem is that when i install labview and usb 6008, i am not able to communicate data logger through labview.
I will be grateful for detailed reply
Regards
sham
(3,280 Views)
Hello Sham,
The USB 6008 is actually supported by our DAQmx driver v7.5.  I highly suggest upgrading your driver and device to get the full functionality of the DAQmx driver.  Logging data in LabVIEW with the USB 6008 will be easier with the DAQmx driver.
Eric
DE For Life!
(3,249 Views)
