pin out on a NI USB-485
Can anyone give me the correct pinout for a rs-485 db9.  I have looked at the pdf that is under the specs section but i dont know which one to use out of the four combos that are available.  I'm only using a two wire network. Thanks.  If you have any question please Email me at aaronladams@gmail.com or call 734-709-0210
(3,072 Views)
Howdy zcar15,
Check out the Pinout For Serial Ports document, that should tell you everything you need to know.
Sincerely,
Chris G in AE
(3,052 Views)
