pitot tube Air pressure measurement through sensor and DAQ card using LABVIEW
hi i m new to lab view.actually i want to digitize a air compressor using DAQ card and Lab view.there are 10 tubes wchich are coming out from the compressor at different stages containing air in them.initially there were inserted in pressure manometer now i want to replace manometer with a computerize software.kindly help me over this issue.
(3,610 Views)
Hi malikyoyo,
It looks like more information would be needed to be able to create a solution. What sort of DAQ card are you using to connect between your air compressor and LabVIEW?
Since you are new to LabVIEW and using DAQ here are a couple of links to help get you started.
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
To really help give advice more information about your system, how you intend to record, display, process the information etc
Definitely follow up if you are in need of more information or help.
James W.
(3,597 Views)
