possible maximum sample rate of DAQCard-6036
Hi All
I'd like to use all channels (16AIs and 2 AOs) if my DAQCard-6036E.
I haven't done this before and I'd like to know the theoretical maximum
sample rate of my AI and AO per channel.
I know if I use AIs only, the theoretical sample rate per channel would
be 200K sample/sec / number of channels. However, I also use 2 AOs
and the AO ouput rate would be degraded when using AIs simultaneously.
Is there any formula to calcultate the possible sample rate?
Ryan
(3,241 Views)
I have not experienced such a behaviour while using AI and AO simultaneously
Did you observe such a 'degrading' of AO output rate??
(3,236 Views)
(3,235 Views)
