problem reading multiple inputs from USB 6009
          I am trying to read multiple Analo inputs from USB 6009. When i hook up the power supplies to the DAQ board, only 1 signal is being read and the others are remaining zero. Could u tell me how to get around with this problem.
(2,916 Views)
How are you trying to read multiple inputs? Is this in MAX or whatever programming language you are using? If it's in a program, can you provide the source code?
(2,910 Views)
