Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
problem writing to Port A, B, C on PCI-2025E
Re: problem writing to Port A, B, C on PCI-2025E
Russell
NI Employee (retired)
09-24-2002
11:27 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Thanks for the diagram. This is correct. So if you use the +5V supply on the board to drive the relays, you have up to 1 Amp available. At 10 mA per relay, you will be well below that.
0
Kudos
Message
11
of 11
(512 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
