problems when using ULx provided by MCC
Hi, I am using PCIM-DAS16JR/16 from MCC. It has detected by Instacal. But when I launched the example, an error happened as below. Can anyone solve it?
(3,418 Views)
Did you notice that this forum is sponsored by National Instruments and that this board is for NI DAQ cards?
It does look like MCC is using similar functions to DAQmx. If that is the case (and do check with MCC), "i1" would not be legal. With a physical channel with NI hardware/software, you can click on it to select a valid channel and you would not type something in. An NI channel would be something like 'Dev1/ai0'.
Again, refer to the manual and their tech support.
(3,408 Views)
