problems with DAQ on PDA with CF 6004
Hi, Eran.
To answer your first question, there's an Express VI that does exactly what you describe. It's called Elapsed Time, and you can find it on the Functions>>Programming>>Timing subpalette.
Sarah K.
Search PME
Message 21 of 27
(1,744 Views)
 I have the same problem as Eran. I am trying to sample 4 channel (with acelerometers) continuously at rates of 4096 Hz. I dont want present data on the screen of the PDA. I want save data into a file. The program stop with an error (2000361) and the file doesn´t contains all data. How can I do to solve this problem?.
I have attached my VI.
Thanks.
Message 22 of 27
(1,434 Views)
Hello Javo,
Thanks for your post.
Take a look at the link below as I beleive it will solve the issue you are having.
Error -200361 While Performing Data Acquisition on a PDA
Also what Operating system are you using this device on? There have been documented issues with this error on an XP machine with Service Pack 1 installed. See the link below.
Error -200361
The error for this link is a little more specific to certain devices but could apply in your situation.
Please reply if you have more questions.
Corby_B
Message 23 of 27
(1,406 Views)
Thanks Corby for your reply.
I have changed my VI but i have the same problem. After conitnuous runnig of about 2 minutes i got the error message "200361".
I put the IO "write to text file" outside the loop While as recomendations that you sent me says.
I think that the problem is the PDA ( Acer n50) , but i don´t know.
I have attached my VI. If you have any suggestion, would you mind send to me, please.
Message 24 of 27
(1,384 Views)
Javo,
Do you have any other PDAs you could try it with?  How fast is the processor in your PDA?
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
Message 25 of 27
(1,348 Views)
Hello Eriquito.
The processor in my PDA is:  Intel(R) PXA272  312 MHz.
I want to acquire data at rates of 4096 Hz with 4 channels. Do you think that is a high rate?.
Thanks.
Message 26 of 27
(1,345 Views)
Hi Javo,
You can try simplifying the way you are combining your data every loop iteration. This will let the loop execute faster and possibly read the data without error. Make sure to set the build array block to concatenate inputs. This can be selected by right clicking on the build array block. I’ve included a screenshot of one way to simplify the concatenation. If this does not work I would try lowering the sample rate until you can acquire without error. Let me know if you have any questions.
Message Edited by Nathan_R on 05-15-2008 05:01 PM
Nathan
NI Chief Hardware Engineer
Message 27 of 27
(1,324 Views)
