property node DAQmx Buffer not available
I transferred an intact VI from from my desktop PC to a laptop. On the laptop the VI does not compile since the property node "DAQmx Buffer" is not available. I suspect that I maybe did not install the full DAQmx suite on the laptop but I don't know which part might be missing.
(On both machines there is no DAQ hardware installed since I was just trying to do some editing.)
Is my suspicion correct? and how do I find out what's missing'?
If my suspicion is not correct: what else could it be?
TIA
Franz
(2,905 Views)
hello franz,
which versions of DAQmx do you have installed on both machines?
if they are the same, try to repair the DAQmx installation at:
"start -> control panel -> software -> ni software"
regards,
robert h
NI germany
(2,890 Views)
