10-08-2007 02:13 PM
10-09-2007
10:12 PM
- last edited on
07-18-2025
09:33 AM
by
Content Cleaner
Hi Ralph,
I have some questions to help troubleshoot this issue. Is your measurement single ended or differential? For more information about this, see this tutorial. Do you see this fluctuation if you attach the sensor to a different channel and read from this? Do you also see the same behavior from Measurement & Automation Explorer (MAX)? Do you see the same behavior if you attach a constant voltage source (such as a battery) to the channel?
10-10-2007 11:47 AM
