pxi-6133 tb-2709
I have a PXI-6133 with a TB-2709.  I want to get access to the PFI1/AI Ref Trig on the PXI-6133 but the TB-2709 only gives me access to PF0/AI Start Trig.  Is there a way I can access both PF0/AI Start Trig and PFI1/AI Ref Trig without wiring directly to the PXI-6133 connector?
(4,121 Views)
If you want to use both triggers you will need a different terminal block. The 2709 only breaks out the AI lines and the start trigger.
The product page for the 6133 suggests the SCB-68A.
(4,097 Views)
