pxi-6289 digital inputs sinking or sourcing?
I am ordering some sensors that I will read as digital inputs on the PXI-6289. I can get them in two different configurations: PNP (sourcing) or NPN (sinking). I would like to get the PNP version with the assumption that the digital inputs of the PXI-6289 are sinking inputs. Is that correct?
I know that the dital lines can be configured to either inputs or outputs.
How does that electrically work? inputs => sinking, outputs => sourcing? Please explain.
Thanks for your response.
(2,912 Views)
Hello twolters,
There are a lot of good documents on the ni.com website that explain sinking and sourcing.  I would recommend you take a look at them and hopefully they will answer your questions.  To search the site just go to www.ni.com and then in the top right hand corner there is a search field.
Understanding Sinking and Sourcing
How Do I Connect Two Sinking I/O or Two Sourcing I/O Together?
Choosing the Right Industrial Digital I/O Module for Your Digital Output Sensor
Have a great day,
Brian P.
(2,891 Views)
