python DAQmx Trigger an output response with an input signal
Hi everybody,
I'm using a NI-6251 board with a GUI python.
I want to send data on output channel on each falling edge of an input signal when I click on a start button.
The level of the output signal can be 0/1 (0v/5v).
The input signal square frequency is 2MHz during 50 tops (see the attached file for further informations).
I don't know if it is better to use Analog input or counter input for the input signal. I think I must define a timing signal at 10MHz frequency.
I have tried more solutions with bad results.
Does somebody have answers to my problem?
Thanks in advance.
(6,045 Views)
Hi 22buzz22,
I think you should try this example.
It uses a counter for output generation, trigged by your input signal physically wired on a PFI (name this PFI in the "Source" field).
Open it, try it and tell me if it matches your request.
(6,025 Views)
Accepted by topic author 22buzz22
Thanks for your answer.
It works.....
(5,964 Views)
Dear Mathieu,
I cannot open the link you posted. It gives a message "You do not have access to view this page or to perform this action." although I'm signed in.
Thanks!
(4,181 Views)
