"Error -200077 occurred at DAQ assistant" problem for NI USB-6009 DAQ
Hello
I have this problem with generating signals using the DAQ, and I appreciate any help in solving it
I just got this NI USB-6009 DAQ card; I was trying to generate an output signal
Whenever I try to use NI LabView or LabView Signal Express to generate an output analog signal, I get an error in the DAQ Assistant screen, following is the error:
DAQ Assistant Error
Details:
Error -200077 occurred at DAQ Assistant
Possible Reasons:
Measurement Requested value is not a supported value for this property.
Property: SampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
I just chose the following options in the DAQ Assistant screen:
Channel Settings: VoltageOut
Timing settings: N samples (or Continuous Samples)
Test Signal Type: Sine Wave
Physical Channel: AO1
I tried to check the Measurement and Automation Explorer, in the Test Panels screen, Analog Output Tab... I found that the Rate, Transfer Mechanism, Frequency, and Stop options are disabled.
In the self-test (from MAX), the device passed the self-test
I use Windows Vista
I attached some print screens
So, how to fix this problem? I need to use this USB card as a function generator, so I need to be able to generate signals using this card!
any help...
Thanks alot
Abdallah
(7,052 Views)
You get an error when trying to specify sample timing because sample timing is not supported with that DAQ device. As the error message states, you only have on-demand output. This is software timed output - a single point at a time. As the manual/specs state, the best output rate you can achieve is a couple of hundred hz and this is going to be subject to quite a lot of variation and jitter because of the uncertainies of any software timed operation. If you need higher frequencies and better resolution, you need to use a different device.
(7,045 Views)
