"WindowsXPUSBHotfix" error on DAQ USB-6001
I've just bought NI DAQ USB-6001 and install DAQmx v15, then I try to test the DAQ, and I've got the error. Please refer to attached pictures for more detail. My windows system is Windows XP (SP3). I try to search for "WindowsXPUSBHotfix" and found that I need to update service pack 3, but I've it already. Please refer to  NI-DAQmx 15.1 f2 Readme
Thank in advance,
Aung
(7,075 Views)
So you didn't actually install the hotfix to sp3? Since you are using an unsupported version of Windows, why is this a problem for NI?
(7,061 Views)
Yes, you're right, Dennis. I downloaded and installed wrongly the fix from Microsoft. The correct fix is WindowsXP-KB969238-x86-ENU.exe
Aung
(7,035 Views)
