Environment :
NI-DAQ 6.9.3
PCI-6025 E Card
LabPC1200 Card
PCI serial interface card
AGP video Card
Measurement & Automation explorer 2.0
After using the PCI-6025 E during an hour with the Measurement & Automation explorer 2.0 software, the message :�Le périphérique ne repond pas à l�adresse de base, voulez vous continuer?� or « the device does not respond to is base address, do you want to continue ? »
All the informations , even in the System Configuration Panel, seem to be in order. It seems that the problem occurs after I have tried to use also the Lab PC 1200 by the way of the Measurement & Automation explorer 2.0.
I have tried to:
� restart the software,
� stop the PC and restart it after a while,
� uninstall NI-DAQ 6.9.3 and all NI softwares
� Install NI-DAQ 7
The same problem was always here.
� stop the PC remove all the Cards except the video card
� restart the PC
� stop the PC and put only the PCI-6025E Card
� uninstall NI-DAQ 7 and all the NI softwares
� stop the PC and remove the PCI-6025E Card
� Install NI-DAQ 6.9.3
� Stop the PC and install the PCI-6025E Card in another PCI Slot.
I have each time try to change the number of the card by the use of Measurement and automation explorer 2.0 but with no success.
How can I do to use again this card?
I really thank you for any response.
NICOLAS Gabriel.
