range selection on the PCI-6071E?
I need to know how to set the input range to 0 to 100 mv for the PCI-6071E ? It says its software selectable but how is it done. I used the test panel on NI daq-mx, but the only options it gives you is -10 to +10 , or 0 to +10.
(3,085 Views)
With a simulated device, I have no problems setting those limits. What version of DAQmx are you using. The limits you mention aer for the analog out. Are you also sure that you are on the correct tab?
(3,082 Views)
THanks for the information. I am using version 3.0.2.3005 of daqmx. I think is an older version and I will upgrade to newer version.
(3,064 Views)
There is no such thing as DAQmx version 3 anything. You are probably confusing the version of MAX with DAQmx. In any case, an upgrade is probably called for.
(3,062 Views)
