read data NI USB 6008 python
       I have problem when I call the NI USB 6008 read function in Python script.
I implement the read function in C++ and the function is verified in C++. When I call the read function in python script, the read function always outputs the initial value which is 0.0 . I use swig between python and C++.
C++ code of the reading function:
 void DAQAIRead::read()
    mlString    task( "AITask" );
    TaskHandle  handle;
    // Channel parameters
    char        chan[] = "Dev1/ai0";
    float64     min = -10.0;
    float64     max = 10.0;
    // Timing parameters
    uInt64      samplesPerChan = 1;
    // Data read parameters
    float64     data=0.0;
    int32       pointsToRead = 1;
    int32       pointsRead;
    float64     timeout = 10.0;
    int32       nrSamps=0;
    int32 rv =0;
    // Init
    rv = DAQmxBaseCreateTask( task.c_str(), &handle );
    cout<<"DAQmxBaseCreateTask:handle:"<<handle<<endl<<"&handle"<<&handle<<endl;
    rv = DAQmxBaseCreateAIVoltageChan(handle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,min,max,DAQmx_Val_Volts,0);
    rv = DAQmxBaseStartTask(handle);
    rv = DAQmxBaseReadAnalogF64(handle,DAQmx_Val_Auto,10.0,DAQmx_Val_GroupByChannel,&data,1,&nrSamps,0);
    rv =  DAQmxBaseStopTask(handle);
    cout<<"data :"<<data<<endl;
I get correct data value by calling from C++. If I call this function from Python script. I always get 0.0 which is the initial value of data.
Is there anyone has similiar problem and would like to share your idea about how to solve it?
Thank you!!
(6,014 Views)
Hi Feiteng,
Officially NI does not support questions regarding Python. However, NI provides some information on how to program NI DAQmx applications using Python.
Please take a look at the following webpage.
There you will find some instructions.
I hope this will provide you with a working solution.
Peter S
(5,947 Views)
