10-09-2007 07:43 AM
10-09-2007 11:48 AM
10-09-2007 12:07 PM
I'm using pins P2.0-P2.4 for the wiring. The LEDs are just to indicate the correct operations at the terminals W, G, O, B etc. So it just indicates which terminal is active. I'm trying to replicate this LED output in LV.
The LEDs are connected to the terminal block, and each terminal block is connected to each port (channel) by means of a wire. '
The voltage is 5V, which I am acquiring from the DAQ unit itself.
There is an interface board between the thermostat and the DAQ unit, to help me replicate the actual output.
10-09-2007 12:19 PM
10-10-2007 06:45 PM - edited 10-10-2007 06:45 PM
Hi Smm:
If can you take a look in the manual NI USB-6501 User Guide and Specifications, page 7, it has the connections for driving and reading voltages from the digital input and ouput lines. A simple draw of your circuit will help a lot figuring out what is the problem? Make sure that the “anode (positive)” of diode is going to the digital line (input) and the “cathode (negative)” is going to the digital ground. If I were you I will try reading the 5 volts removing the phisical LED.
Message Edited by Jaime F on 10-10-2007 06:48 PM
