read/write analog input and output
hello!
I have the card PCI 6221 and I have to manage 5 analog inputs and 1 analog outputs.  I have no problem reading analog inputs and writing analog outputs. however, I would like to read the analog output by routing it to an internal port. But I see an error: -50103ressource reserved.
How can it be possible to do this measure?
Thanks.
(3,256 Views)
Since this DAQ card uses multiplexing to read/write inputs/outputs make sure you use only 1 task for analog input and 1 task for analog output.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,221 Views)
