reading 4 - 20mA pressure signal
I am using a usb 6211 multifunction DAQ and trying to continuously read 4 - 20mA signals from a Pressure Transmitter.
My problem is that I do not get a steady signal out.
The signal jumps about and wildly varies almost looking like it reads out of phase but i thought that the 4 - 20mA signal would be constant?
Does anyone have any ideas?
Cheers
Johnny
Message 1 of 11
(4,939 Views)
Hi Johnny,
Can you tell me how you connect the 4-20mA signal to your DAQ and which DAQ input do you use ?
Before I tell you things you already might know.   Smiley Wink
Message 2 of 11
(4,924 Views)
I am using ai2 putting the -ve of the transmitter to the +v terminal of the DAQ and the -ve of the 10v power supply to the negative of the channel. The +ve of the transmitter connected to the +ve of the transmitter.
Johnny
Message 3 of 11
(4,919 Views)
What you need is a resistor in series with the 4-20mA loop. You measure the voltage across that resistor and you can calculate the current.
Use 250E for a voltage from 0-5V
Do you understand this ? If not I will make you a drawing. If I understand you correctly you have a passive transmitter
Message 4 of 11
(4,915 Views)
sorry i forgot I have a 100ohm resistor across the channel.
Is the problem that it is 100ohm??
Message 5 of 11
(4,912 Views)
It depends what minimal resistor value your device accepts.
Can you draw the connecting or point it out in a manual of your transmitter. The connection you described is not clear to me.
Message Edited by K C on 12-06-2007 10:41 AM
Message 6 of 11
(4,908 Views)
Where can i find that?
Would it be in the manual or on a data sheet?
Johnny
Message 7 of 11
(4,906 Views)
Yes, it must be in the datasheet of your transmitter. Can you tell me what transmitter you use ?
See also the edited part in the previous answer.
Message 8 of 11
(4,903 Views)
KC,
I have tried to attach files but the server keeps timing out.
I am using a druck 7517 transmitter.
Johnny
Message 9 of 11
(4,898 Views)
OK, I think the resistor value is OK.
Are you sure you have the resistor, power supply and transmitter connected in series ?
Message 10 of 11
(4,887 Views)
