reading an analog voltage signal
the signal is required on a labview6.1 V.I. via an Adlink DAQ-2010 card
(2,586 Views)
Greetings,
Adlink will probably have a driver for this device that you can use to interface with it. Your best best will be to contact Adlink support or check their website for what they offer.
If they have a dll for the device, you could use the Call Library Function node (within the Advanced subpalette of the functions palette) in LabVIEW to interface with the dll.
I hope this helps. Let me know if you have any questions about NI hardware. We make data acquisition devices that can interface seamlessly with LabVIEW and will save you development time. Have a great day.
Todd D.
NI Applications Engineer
(2,586 Views)
