reg_level_read and reg_level_write
Is it true than u can access the registers directly with these two functions?
And what is the parameter bitSettings in the reg_level_write function for?
I'm using Delphi under Win2000.
(2,734 Views)
Tler,
To receive the highest-quality advice, I would suggest posting questions regarding register-level programming in the Driver Development Kit (DDK) forum.
Driver Development Kit (DDK) Forum
With regards to the Reg_Level_Read and Reg_Level_Write functions, they are obsolete. You will want to use the NI Measurement Hardware DDK to develop your register-level programming applications. It is available for download from the following location:
NI Measurement Hardware DDK (Driver Development Kit)
The following KnowledgeBase contains detailed i
nformation concerning the NI Measurement Hardware DDK:
Measurement Hardware Driver Development Kit Register Level Programming Architecture
Good luck with your application.
Spencer S.
(2,734 Views)
