regarding labview application
hello to everyone.
              i am facing aa problem in which i have a main vi and sub vi. whenever i  try to control the main vi remotly using web server in internet explorer the main vi works very well but sub vi does not execute after pressing the button from which sub vi is assosiated.
(4,255 Views)
You should switch to the LabVIEW Board. Nothing in your description of your problem relates to this board (Multifunction DAQ). When you post in the LV Board, please attach your VI and subVI and give a detailed description of how to reproduce the problem and exactly what you expect or want it to do. The description you posted here does not contain enough information to assist you.
Lynn
(4,236 Views)
