replacement for PCI-6518
Hello, I am upgrading an old PC witch has an PCI-6518. New PC’s have PCIex instead of PCI.
Does any one know if there is a 1:1 replacement for the PCI-6518?Or at least as close as possible?
(1,197 Views)
Looks like all the industrial Digital IO cards are PCI only. The PCIe/USB variants are typically 5V logic.
https://www.ni.com/en-us/shop/category/digital-io.html?productId=118259
Some options
  1. Find a new PC with PCI slot, definitely available in the market, but not the general consumer segment
  2. Redesign your application, find a new card that may fit your application - not guaranteed to satisfy all your requirements, on the way you might need to compromise
Note: No, NI does not support the use of PCIe to PCI adapters, you may try at your own risk, but any issue you encounter will not have any support.
Santhosh
Soliton Technologies
(1,185 Views)
