resetting NI-DAQ SC-2075
I am a Graduate Student at FIT trying to do research and have had problems with the NI-DAQ Board SC-2075.The software continuously is telling me to reset the device and that the device is not available for routing .The error code is 89130.
Please help me with this problem.
(3,177 Views)
Hi Suiluj,
Could you tell me exactly which DAQ board model you are using since the SC-2075 is only a terminal block? You should be able to find out thehardware you are using by opening up Measurement and Automation Explorer (MAX) and expanding the Devices and Interfaces tree.
There is actually a KnowledgeBase article on this error and it lists a couple of troubleshooting steps you could try. Please let me know if thisfixes the issue. (NOTE: The device which needs to be reset is the DAQ board and not the SC-2075).
DAQmx Error Code -89130: Device is not Available for Routing
I hope this helps,
S_Hong
(3,162 Views)
Hi this is Suiluj. I just managed to solve the problem ;two channels needed to be specified in the labview software.Thanks for replying.
Regards
(3,158 Views)
