rising edge phase shift
Hi
I am using a CDAQ 9178 and have a 9229 analogue card. I have two 28V square waves that are aroudn 90 degrees sperated. The frequency is around 10-20hz. I am sampling at 10000 samples per second and recording 20000 samples of data. so two seconds.
How can i measure phase shift between the two rising edges for every pulse.
I am using the 9229 analogue card as it can handle the higher voltage plus all channels are sampled simultaneous
I have attahced my programme.
(4,338 Views)
Hi JWinstanley,
You can measure the phase shift by measuring the time difference between rising edges of each signal.
I have attached a document which may be of use to you: http://www.ni.com/white-paper/4529/en/
Best of luck!
SFuller
(4,306 Views)
