rj50 wiring
At the first, sorry for my English.
I need to create own RJ50 cable(RJ50 on both side), for connecting NI 9944 with NI 9237. I found connection for NI 9237(see my attachment), but I can't find connection for NI 9944. So the question is, cable connection are same for both devices? so cable will be something like attach2?
(3,316 Views)
Hi Igor,
Yes, the connections are the same between the two.  The RJ50 cable is a standard.  You can purchase NI's cables on the 9237 product page.
Feel free to respond if that doesn't answer your question.
Hope this helps,
-Andrew
(3,280 Views)
