route GPCTR1_OUT and RTSI line
I want to route the output of GPCTR 1 to a RTSI line. I have tried the
How Can I Route Counter 1 From the 6115 to a RTSI Line?
from the ni support, where the function Select Signal from the nidaq32.dll is used. But this doesn't work, I get the error message -10003.
I'm using the PCI 6711 and Labview 6.0, might this be the reason?
thanks,
andreas
(3,007 Views)
Message Edited by Jochen on 09-12-2005 11:26 AM
(3,000 Views)
I have found an example in LV 7.0 that routes the counter 1 output to RTSI through the AO update clock. As I can't save it back to LV 6.0 here is the screenshot of the diagram.
Jochen Klier
National Instruments Germany
(2,996 Views)
