run-time package
I would like to extract the set of libraries needed for my application (in C API) to work. Is there any possiblility to define which libraries are neccessary from DAQmx driver? I tried to use Walker Dependency to check which libraries are required but the number of files was quite huge. I want my application to run on different boxes without installing whole DAQmx software on each.
Thanks in advance,
Dariusz Boczkowski
(3,300 Views)
Hi Dariusz,
Thanks for the post and I hope your well today.
The only thing I can suggest is the Runtime Deployment Options Available for NI-DAQmx, please see the following Dev Zone article about the options.
http://zone.ni.com/devzone/cda/tut/p/id/5606#toc7
Let me know what you think,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,289 Views)
Thanks for an answer,
That may solve my problem, but I haven't checked it yet. If I install DAQmx driver in runtime version I will be able to verify the solution. I will describle the effect then.
Dariusz Boczkowski
(3,270 Views)
Hi Dariusz,
Thanks for the reply.
Please do try it and let me know if you any issues.
Kind Regards
James Hillman
(3,267 Views)
