run two loop simultaneously but time doubled
Hi guys,
I am try to read two ion chamber simultaneously. Read IC0 and Read IC1 have one while loop each.
These two subvi can run simultaneously but the time cost still doubled.
Why?
Thanks a lot!
(4,130 Views)
How are you communicating to your chambers?  It is likely the communication API cannot be ran simultaneously.  Therefore one has to wait for the other to complete.
(4,124 Views)
I use RS232 to read there two chambers. (Com1 & Com2)
(4,120 Views)
yeah, your COM vis may need to be marked "re-entrant"...
(4,103 Views)
I tried. It didnt work
(4,095 Views)
Accepted by topic author yonghua.du
Hi guys,
Thanks for your response.
I found the issue. I put the delay between write and read COM. See the following figure. The timer were put in IC101 Resp.vi. After I moved it out, my code can work well.Capture.PNGIt's work well
(4,093 Views)
