running a program
I am writing a program that will generate a square wave with a pause at zero.  I want to output this program through the NI cDAQ 9172.  I keep getting errors when I try to run the program and I do not understand if I am trying to output it in the wrong way or not.  The program is attached and I appreciate and help that you can give me.
(3,889 Views)
That program doesn't make any sense. You have two DAQ Assistants and neither are outputing anything because you have not provided a signal to output. Also, the 9172 is just a chassis and can't output anything anyway. You need a module that plugs into it. You have the DAQ Assistant set for an analog output. Is that the type of module you actually have? If it is, I don't understand why you need two DAQ Assistants. You can create a square wave and have a single DAQ Assistant output that.
You might want to check the resources at the DAQmx Getting Started to learn some basics before trying to write any code or generate a signal.
(3,886 Views)
