running two DAQmx AI tasks concurrently on a single device
Hi,  Is is possible to run two DAQmx AI tasks concurrently on a single device such as a PCI-6225.  For example, say I wanted task #1 to scan analog channels 0-39 at a "slow" rate to update the display at a refresh rate of approximately 4Hz.  At the same time, I wanted task #2 to scan analog channels (from the same device) 0-2 at a "high" rate of 10kHz.  Is this possible?  If not with the PCI-6225 how about with some other NI hardware? Thanks, Brian
(2,921 Views)
This question gets asked a couple times a week it seems. The answer is no, you cannot run two separate tasks. You have a single clock on the board and all of the inputs are muxed to one A/D converter. The standard asnwer is to scan at the fastest rate and in yuor software, discard samples you don't need.
(2,917 Views)
Btb,
Running two tasks for the same card is not going to be an option but this knowledge base includes a possible workaround for using one task.  Keep in mind that this workaround is essentially "tricking" the card to achieve different sample rates which have a common divisor.  The samples taken will not be truly simultaneous, though.
(2,892 Views)
